A Little Lipstick on a Goat
Results 1 to 5 of 5
    Moderator Jim in NC's Avatar
    Colfax, NC
    6,317
    84
    The paint on my '92 Dodge has been thinning out and breaking down for a few years. It needed refreshing before rust and further damage was done. It does what we need just as well as what a newer one would. Here it is in its new suit!
    Senior Member oliverguy's Avatar
    Sep 2013
    Central Illinois
    699
    90
    Quote Originally Posted by Jim in NC View Post
    xcellent work!!
    67 JD 4020, 67 Oliver 1650 , 59 JD 530, 55 Oliver Super 88, 54 Oliver 66, 53 Oliver 77 53 Oliver 88, 50 Oliver 88,50 Oliver 77, 72 Oliver 75 mower, 57 JD 720 , 45JD B, 48 Allis WC
  4. #3
    Cecilia, KY
    3,060
    5
    Ya got it finished. It looks great Jim. Your body man did a good job.
    I see more field time for the old Ford to keep scratches off this one.
  5. Remove Advertisements
    AntiqueTractorsForum.com
    Advertisements
  6. #4
    Moderator Red Kiwi's Avatar
    Hawke's Bay, New Zealand
    1,177
    A good looking ute.
    “Keep your face always toward the sunshine - and shadows will fall behind you.”
  7. #5
    Colfax, NC
    6,317
    84
    Dave the pics don't show it but the top of the cab is gonna be painted again. It was too hot on the day he painted it and it just did not work out well. I take it back in a month to get it buffed again and that's when it will be fixed. The ford you mention had been a good worker. It has been here since new and continues to earn its keep. It wears its battle scars proudly.
