How do I find out who made my bale loader? I did not see any tags on it anywhere. Alos how do I engage the chain to make it pick up the bales? The chain does not want to engage and since hay season is almost here I need to get it working soon. Tganks!
There were several different brands and styles, Kneib was a big one, Henry made one, John Deere. One was called a popup and there was many incline type. Here is a parts list and diagram of the Kneib, now a bush hog.
Does it engage at the axle? May need to clean up the mechanism that engages it. May have a broken spring....James
Yes the chain engages at the axle. There is a sprocket on the axle tube that spins. I cannot tighten it down anywore. How do I get the sprocket to turn with the axle?
Does it have a set screw? Bolt? Is the sprocket worn out from slipping? Is the axle worn? Or is there some kind of release to move the loader down the road....James
I took the axle hubs off today and the bearings are only parts there because they are worn so much. Any idea where I can get new bearings? Napa told me I had to get them custom made.
Related Threads
Antique Tractors Forum
87.1K posts
10K members
Since 2012
