Farmall Super A Touch Control
Results 1 to 4 of 4
    Moderator Jim in NC's Avatar
    Colfax, NC
    6,412
    99
    I replaced the orings on the rods that push the rockshaft a couple of years ago and they have started leaking again. When taking things apart to remove the unit I discovered that there was pressure in the fluid reservoir. Is this common and is there a relief gadget somewhere that could be clogged? To me if there was no pressure the hydraulic oil may not be forced out.
    Senior Member bakerg's Avatar
    May 2014
    Tilbury, Ontario, Canada
    179
    7
    Don't know if this will help but here is a rebuild video, part 1 & 2
    Kind Regards, Gary
    John Deere H 1/2 scale replica??
    Hidden Content
    Hidden Content Link to Antique Tractor Pictures I've TakenHidden Content Hidden Content Hidden Content
  4. #3
    May 2014
    179
    7
    Also a pdf file info for servicing.
    http://www.farmallcub.info/pubs/main...%20Control.pdf
    Maybe check E under trouble shooting.
    Kind Regards, Gary
    Hidden Content
  5. The Following User Says Thank You to bakerg For This Useful Post:
    Jim in NC (03-30-2017)
  6. Remove Advertisements
    AntiqueTractorsForum.com
    Advertisements
  7. #4
    Colfax, NC
    6,412
    99
    Thanks much for the links. Too often I forget about looking on the net. A farmer friend was at the house today, and he said he remembered seeing tractor mechanics rebuild them while still on the tractor. They would remove the battery and battery box and pull the back plate to service it.
