1964 Case 430 rockshaft piston seals
Results 1 to 3 of 3
    Junior Member
    Apr 2017
    1
    0
    Hi every body!
    I'm new to the forum and i'm currently fixing up my 1964 case 430. Wondering if anybody could help me to figure out how to install the smaller piston seal on the rockshaft? I'm not sure in which direction the seal's lip has to face . And also is there a trick on getting the ring on the shaft. The ring seems awfully tight.Thank you George
    Cecilia, KY
    3,186
    5
    I've never changed a seal on a 430 rockshaft piston, but as a rule of thumb the oil should push against the open or flared end of the seal.
    A little dish soap with a few drops of water, or you're "slickem" of choice will help getting it in place.
  4. #3
    Moderator Jim in NC's Avatar
    Colfax, NC
    6,484
    105
    I cannot speak to your particular situation but from having worked on old tractors I know that most replacement seals are much narrower or have a smaller thickness than the original seal. If the shaft has any obvious wear I usually replace the original seal with two seals. That has worked good for me. As Dave says making things slicker will help and reduce possible seal damage during the replacement.
