Pulling season is almost here.
Results 1 to 6 of 6
  1. #1
    Junior Member
    Oct 2016
    Southern Maine
    6
    We have had a banner winter with way above average snow. But spring is in the air and already been prepping the 70 for hooking to the sled. Learned a lot last year now plan to capitalize on it moving the weight 18" behind the rear axle.
  2. The Following User Says Thank You to mdross For This Useful Post:
    Wi11y (04-07-2017)
  3. # ADS
  4. #2
    Super Moderator BigDaveinKY's Avatar
    Cecilia, KY
    3,186
    5
    Should be starting soon here in KY. Good luck with your tractor. Hope the modifications help.
    No matter where you go.......There you are.
  5. #3
    Moderator Jim in NC's Avatar
    Colfax, NC
    6,484
    105
    Doing similar things here but for different reasons. I have been going over my working tractors trying to get them ready for farming chores. A little fine tuning helps them too. Good luck pulling!
    "Farming looks mighty easy when your plow is a pencil and you're a thousand miles from a cornfield." ~ Dwight D. Eisenhower
    "Heaven is under our feet as well as over our heads." Henry David Thoreau
  6. Remove Advertisements
  7. #4
    Senior Member oliverguy's Avatar
    Sep 2013
    Central Illinois
    825
    95
    our rules wont allow for weight behind the axle for one club that i pull with. The other does Took a couple 88's out to Iowa a couple weeks ago to Sigorney and had a early start pulling. Next one will be in 2 weeks!
    67 JD 4020, 67 Oliver 1650 , 59 JD 530, 55 Oliver Super 88, 54 Oliver 66, 53 Oliver 88, 50 Oliver 88,50 Oliver 77, 72 Oliver 75 mower, 57 JD 720 , 45JD B, 48 Allis WC
  8. #5
    Junior Member
    Apr 2017
    1
    Can't wait to get started!
  9. #6
    Moderator wizzard's Avatar
    symco,wi
    997
    32
    Quote Originally Posted by oliverguy View Post
    I went to Sigourney a couple years ago, those guys don't mess around! ended up 4 from last lol
    Bert.
