Battery life
Results 1 to 5 of 5
Thread: Battery life
    Senior Member
    Aloha, OR formerly Fargo-ND
    286
    0
    Battery life
    My pickup is 14 and some years old and still has original batteries.
    Mileage is 39,9++. How long can I expect them to last?
    I have always been very careful to keep them well charged, even during the ND winters when I lived there. The posts are still clean too. I did use a battery post spray on them when it was new.
    A big Thank You in advance.
    just rjR
    Let me write about your collection; real or toys. I have a high published to submitted ratio.
    Senior Member Wi11y's Avatar
    Jun 2016
    Sorrento, Maine
    522
    406
    6 years normal use.
    If you live in a temperate area maybe 10 years. My zero turn mower that is used only in the summer time had its battery last almost 14 years, then again it also has a solar panel to keep the battery topped off.
  4. #3
    Cecilia, KY
    3,132
    5
    It's always a craps shoot. I've had them last from two years to twenty years. The average life of a wet cell battery lead acid battery is seven to ten years. Once you pass that you've beaten the odds. On a good note, the batteries that didn't live up to the warranty date my dealers have always pro-rated a discount. You say "Batteries" so I'm guessing a diesel engine. You've done good. So to answer your question How long can I expect them to last? You could be replacing them at any time. Only answer I can give you with such an unpredictable device.
  5. The Following User Says Thank You to BigDaveinKY For This Useful Post:
    Wi11y (04-12-2017)
  6. Remove Advertisements
    AntiqueTractorsForum.com
    Advertisements
  7. #4
    Moderator Jim in NC's Avatar
    Colfax, NC
    6,414
    99
    I have had an IH 274 since around 1990, can't recall the exact year of purchase. I have only put one battery in it since I have owned it. I used it yesterday preparing garden ground and looked the best I could to find the age of its battery. Since I am bragging on it I will knock on wood immediately after making this post. Most of my batteries seem to last 5 to 7 years. I might have 2 or 3 older than that.
  8. #5
    Member
    Sep 2016
    A very cold dark place
    32
    0
    Smile
    2004 Cummins turbo 5.9 diesel bought new March 2004, batteries are still fine today.
  9. The Following User Says Thank You to trail twister For This Useful Post:
    Wi11y (04-14-2017)
