New David Brown owner.
Results 1 to 4 of 4
  1. #1
    Junior Member
    Apr 2017
    I have recently bought a tractor that has the Case 1410 emblem on the hood. Seems as though it may not be the case. The serial number for this tractor is #1412111205138. My first question would be, is it a 1410 or 1412. What year was it made? I have a hydraulic issue with the three point and the shop manual does not have an accurate description of the configuration that is on my tractor. I have looked in the parts manual and it is the same as the shop manual. Was there a different model or configuration of the same model that I can look into? What I have is the control valve as a unit incorporated into the casting for the differential, the manuals show this as a component part. Any help or insight into this would be great. Thanks for your time and consideration of this.
  2. # ADS
  3. #2
    Super Moderator BigDaveinKY's Avatar
    Cecilia, KY
    3,132
    5
    My information says the David Brown 1410 was the geared transmission version and the 1412 was the Hydra-Shift.
    So I'm guessing yours is the Hydra-Shift. My information doesn't have a serial number breakdown, sorry.
    You can click on this link and find parts schematics of your tractor........ http://partstore.caseih.com/us/parts...pc::model_find
    Hope this helps some.
    No matter where you go.......There you are.
  4. #3
    Junior Member
    Apr 2017
    Thank you for your input. The parts diagram in the link shows a different configuration for the hydraulic control valve. The one I have is incorporated into the differential casting and not a component part. That is my big issue, I don't know what I am getting into.
  5. Remove Advertisements
  6. #4
    Senior Member Aussie John's Avatar
    Mar 2012
    Darling Downs farming area, Queensland
    267
    7
    I have sent you a message regarding the David Brown Tractor Club where you will be able to get more assistance.
    John
