1947 model A
Results 1 to 5 of 5
Thread: 1947 model A
    Junior Member
    Nov 2016
    12
    0
    1947 model A
    Y'all haven't heard from me in awhile. I'm 15 years old and I'm restoring my great grandfathers tractor. I need some tips on how to paint it. Should I paint most of the parts before install. Block/head and most others? Or should I re assemble then paint it? This is my first restoration and I'm not sure how to go about it. Any tips are greatly appreciated.
  2. The Following User Says Thank You to Mosedizzle_41 For This Useful Post:
    John P (05-27-2017)
  3. # ADS
  4. #2
    Senior Member Wi11y's Avatar
    Jun 2016
    Sorrento, Maine
    597
    467
    Paint it before you assemble it. It really makes the job look 100% better.
    If you do it the other way around? All the bolts and screws will have paint sealing it all together. Then when it gets serviced for what ever repair, the mechanic will destroy the paint job. And it will look really crummy at any place it is taken to be shown off.
  5. #3
    Super Moderator oldman1151's Avatar
    Northwest Ohio
    699
    43
    Quote Originally Posted by Wi11y View Post
    Good advice Wi11y. The way you describe can make quite a difference plus underlying surfaces get painted too instead of being covered over by other parts. Those can be a place for rust to start.
    Touch up may be required after assembly but that is different than just painting/sealing bolts and screws to the rest of the tractor.
    I think the more you can have taken apart before painting the better the outcome.
    1925 McCormick Deering
    1937 John Deere B
    1937 John Deere BO
    1942 Oliver 70
    1942 Farmall A
    1942 Farmall BN
    1948 John Deere A
    1950 Case SC
    1952 Cub
    1953 John Deere 60 All Fuel
    1955 Ford 860
    1966 John Deere 2510
    1968 John Deere 2520
    1982 John Deere 4240
  6. The Following User Says Thank You to oldman1151 For This Useful Post:
    Wi11y (05-09-2017)
  7. Remove Advertisements
    AntiqueTractorsForum.com
    Advertisements
  8. #4
    Jun 2016
    Sorrento, Maine
    597
    467
    Grin, dont forget to use something like a piece of rigid foam insulation to hold the bolts separate for their own painting. Nothing helps make a good paint job by having the bolts painted pre-assembly.
  9. #5
    Northwest Ohio
    699
    43
    Yep. Foam or cardboard. It is important to paint the underside of bolt heads too.
    1937 John Deere B
    1937 John Deere BO
    1942 Oliver 70
    1942 Farmall A
    1942 Farmall BN
    1948 John Deere A
    1950 Case SC
    1952 Cub
    1955 Ford 860
  10. The Following User Says Thank You to oldman1151 For This Useful Post:
    Wi11y (05-09-2017)
