Excitement
Results 1 to 7 of 7
Thread: Excitement
    Senior Member 4imnotright's Avatar
    Waterloo, IL.
    2,552
    0
    Excitement
    Things got a little exciting around here Sunday afternoon. First a helicopter spraying weeds hit a power line and crashed. Pilot is OK. Then Bar B Que grill fire set a house on fire. Pretty well gutted the house.
    Steve
    1956 Massey Harris 333
    1948 Allis Chalmers C w/ wide front end
    Senior Member Wi11y's Avatar
    Jun 2016
    Sorrento, Maine
    597
    467
    Ok I will bite. Why were they using the barbecue inside the house?
  4. #3
    Waterloo, IL.
    2,552
    0
    Willy, all I know is thr grill was on the deck, and that's where the fire started
    Steve
  5. The Following User Says Thank You to 4imnotright For This Useful Post:
    Wi11y (05-09-2017)
  6. Remove Advertisements
    AntiqueTractorsForum.com
    Advertisements
  7. #4
    Moderator Jim in NC's Avatar
    Colfax, NC
    6,475
    105
    Local ordinances prohibit the use of grills on apartment decks because of the fire risk. I do not think grilling at one's own home is restricted. Wherever there is fire one must always pay attention to it.
  8. The Following User Says Thank You to Jim in NC For This Useful Post:
    Wi11y (05-09-2017)
  9. #5
    Jun 2016
    Sorrento, Maine
    597
    467
    People here in Maine are foolish. From running generators in their home, be cause it was too cold to refuel the generator outside. To burning their houses down with the barbecue because they thought "wouldnt it be great to have that smokey smell inside". Yeah, they are that bright around here.
  10. #6
    Senior Member
    Aloha, OR formerly Fargo-ND
    292
    0
    Do not limit that level of ingrained stupidity to your area; it is indeed nationwide and spreading! They schools teach a lot of things that just make no sense. Look at a 6th grade math book. It is more to cause confusion than to help someone live in the real world. They can not even figure out that 1/2 dozen is six without going through 14 or 15 steps! Our country is being "dumbed down" on purpose! Much easier to herd sheep than wolves!
    just rjR
    Let me write about your collection; real or toys. I have a high published to submitted ratio.
  11. #7
    Moderator prwttsh's Avatar
    N. Illinois
    1,555
    20
    That's the kind of excitement nobody needs.
    Rain makes grain
    Bruce
  12. The Following User Says Thank You to prwttsh For This Useful Post:
    Wi11y (05-12-2017)
