Downsizing the fleet
Results 1 to 5 of 5
    Member
    Nov 2014
    72
    0
    As many of you know my tractors and other toys are dear to my heart. Sooner or later there comes a time to downsize. That being said, that time has come for me. Later this summer I will be having an auction. The following is a partial list of what will be on offer for any of you who wish to make the journey up to the geographical center of the sunny province of Alberta.
    1940 MH 201 (Serial # 91203)
    1953 MH 55 Hillside (Serial # 55D1WH15100P)
    1967 Case 1030 (Serial #8349212)
    1952 MH 44 with Ezee On loader, long kingpin front axle (Serial #44GS17697)
    1938 JD D (built half unstyled and half styled)
    1973 Kenworth LW 923 350 Small Cam Cummins, 13 spd trans( 9513 Series), rubber block suspension, SSHD rear ends 4.63 ratio,
    15 ton hydraulic winch, two sets of tire chains, last certified 2014
    NH 488 haybine
    IH 214 round baler
    JD 410 round baler
    JD 4-14 plow
    MH 3-16 plow
    5 Wheel hay rake
    1 cylinder auger engine (magneto ignition, running)
    1947 GM 1/2 ton (parts)
    1948 GM 1/2 ton (parts)
    1964 IH 1/2 ton will run but needs fuel pump
    1967 IH 3/4 ton (engine stuck but truck is restoreable)
    Briggs & Stratton 10,000 watt generator
    Honda 6500 watt generator (runs but uses oil)
    1991 GMC 1500 needs engine, body in decent condition
    1998 Dodge 1500 4x4 powertrain in good condition, computer issues, serious body rust
    1993 Dodge 250 2wd Cummins Turbo Diesel 5 spd Club Cab (250,000 km on powertrain), body in bad shape
    6ft Brush Mower 3 point mount
    and much much more
    Will post more information when sale date and time are decided.
    Senior Member Wi11y's Avatar
    Jun 2016
    Sorrento, Maine
    568
    448
  4. #3
    Member
    Nov 2014
    72
    0
    Got the cut off date to put items in set for May 31, 2017 and the sale will be in mid July 2017. Did this so that any of you considering making the journey had a good amount of time to plan. I will have an exact date at the end of the month
  5. Remove Advertisements
    AntiqueTractorsForum.com
    Advertisements
  6. #4
    Senior Member
    Depoe Bay Oregon
    449
    Long time no see. Sorry to hear, truck and all or you have another. What are you up to now a days....James
  7. #5
    Member
    Nov 2014
    72
    0
    Hauling logs in the winter time and relaxing and enjoying life all summer James. Getting rid everything but 2 of my tractors that run. Keeping all the parts tractors and ones that just need to be got running. Will be building more but going at it at a much slower pace. That being said, the two IH trucks will have a new home in Texas whenever Ray and I can get a program together to get them there. I live in an area where internet and cell service are a hit and miss thing. Not ignoring anybody just don't get online much anymore.
