One more running. . .
Results 1 to 7 of 7
    Junior Member
    Jun 2017
    6
    0
    First I got the backhoe running. It's a Case CK530.
    Then I got the IH Cub running.
    Now I have the IH T6 running!
    Things are looking up!
    BW
    Sent from my SM-G900V using Tapatalk
  2. The Following User Says Thank You to ol'bw For This Useful Post:
    Wi11y (06-11-2017)
  3. # ADS
  4. #2
    Moderator Red Kiwi's Avatar
    Hawke's Bay, New Zealand
    1,207
    5
    That would be very satisfying.
    “Keep your face always toward the sunshine - and shadows will fall behind you.”
  5. #3
    Junior Member
    Jun 2017
    6
    0
    I tried to post videos of each running, but I can't seem to do it thru Tapatalk.
    BW
  6. Remove Advertisements
    AntiqueTractorsForum.com
    Advertisements
  7. #4
    Senior Member Wi11y's Avatar
    Jun 2016
    Sorrento, Maine
    598
    469
    host it on youtube and share the link
  8. #5
    Moderator prwttsh's Avatar
    N. Illinois
    1,555
    20
    Always a good feeling when you get them to run.
    Rain makes grain
    Bruce
  9. #6
    Senior Member oliverguy's Avatar
    Sep 2013
    Central Illinois
    824
    95
    nothing better than to hear that engine running again.
    67 JD 4020, 67 Oliver 1650 , 59 JD 530, 55 Oliver Super 88, 54 Oliver 66, 53 Oliver 88, 50 Oliver 88,50 Oliver 77, 72 Oliver 75 mower, 57 JD 720 , 45JD B, 48 Allis WC
  10. #7
    Moderator Jim in NC's Avatar
    Colfax, NC
    6,482
    105
    I am sure you will find plenty of work for them! Good job!
