Anti seize???
Results 1 to 6 of 6
Thread: Anti seize???
    Cecilia, KY
    3,188
    5
    Anti seize???
    There is a thick, tacky, black grease type coating that works as an anti-rust and anti-seize. It may be, I don't know, thus the inquiry. The p.o. of some equipment I have used it. One thing was a steering wheel shaft and nut, another was lug bolts on a wheel disc. It doesn't dry up or get hard, doesn't allow a tightened nut or bolt to loosen, but prevents rust like nobody's business, and one can readily disassemble after 20 years sitting outside. Anyone know what it is, is it still made, and where I might find it?
    Super Moderator oldman1151's Avatar
    Northwest Ohio
    701
    43
    I use what is called Never Seize made by Locktite. Does exactly as described but is silver in color. I think Amazon sells it as well as local farm/auto parts stores in my area. Great stuff.
    1925 McCormick Deering
    1937 John Deere B
    1937 John Deere BO
    1942 Oliver 70
    1942 Farmall A
    1942 Farmall BN
    1948 John Deere A
    1950 Case SC
    1952 Cub
    1953 John Deere 60 All Fuel
    1955 Ford 860
    1966 John Deere 2510
    1968 John Deere 2520
    1982 John Deere 4240
  4. #3
    Moderator prwttsh's Avatar
    N. Illinois
    1,556
    20
    I second that. I use it alot of it from wheel bolts, to regular nuts and bolts, to shafts and bearing installations.
    Rain makes grain
    Bruce
  5. Remove Advertisements
    AntiqueTractorsForum.com
    Advertisements
  6. #4
    Cecilia, KY
    3,188
    5
    I like the Loctite copper anti seize. Have used it for as long as I can remember (which sometimes ain't too far in the past).
    After pondering on it for a while I think what I'm looking for is a graphite axle grease.
    It would have the properties that I see including the viscosity, anti seize, longevity and hard to wash off one's hands.
    Found what I am looking for and can get it at my local Fastenal https://www.amazon.com/dp/B00JRT97X6...ing=UTF8&psc=1
  7. #5
    N. Illinois
    1,556
    20
    I've heard of that, but never used any.
    Rain makes grain
    Bruce
  8. #6
    Senior Member Aussie John's Avatar
    Mar 2012
    Darling Downs farming area, Queensland
    280
    7
    I have used Stockholm tar, otherwise known as Pine Tar which used also to seal wood and used as a veterinary care product, as an anti seize compound to keep the steering tie rod ball joint ends from seizing in the threaded tie rods on Caterpillar haul trucks. On these, the threads were 1½" by 12TPI and seized up frequently as these trucks were working in very wet conditions. We also wrapped the threaded joint in a greasy waterproofing tape called Denso tape to seal the joint further.
