post yer location and curent weather - Page 135
Page 135 of 156 FirstFirst ... 3585125133134135136137145 ... LastLast
Results 1,341 to 1,350 of 1551
  1. #1341
    Senior Member 4imnotright's Avatar
    Waterloo, IL.
    2,554
    52 this morning at 5 AM. 56 now with a high of 61. Light rain
    Steve
    1956 Massey Harris 333
    1948 Allis Chalmers C w/ wide front end
  2. # ADS
  3. #1342
    Senior Member Aussie John's Avatar
    Mar 2012
    Darling Downs farming area, Queensland
    278
    7
    Queensland, Australia.
    Our real hot weather may be over now but we have a category 4 cyclone (hurricane in the northern hemisphere speak) that has just hit the north coast in the Mackay / Ayr with winds gusting over 250 kph and lots of rain. One area up on the coastal ranges had over 800mm (30" approx today). Its moving inland now and been down graded. The rain depression is expected to travel inland and south towards my area in 2 day's time and there is expectations we could get between 4 to 8" of rain from it. This would be good as it will help break our drought. At present about 75% of Queensland is drought declared as there has been very little summer rain. Does not look like much catastrophic damage shown on our news though, only superficial damage such as trees down, no power or phones, roof, window & verandah damage along with a lot of water around.
  4. #1343
    Senior Member oliverguy's Avatar
    Sep 2013
    Central Illinois
    825
    95
    47 now in central IL heading to 59 for the high
    67 JD 4020, 67 Oliver 1650 , 59 JD 530, 55 Oliver Super 88, 54 Oliver 66, 53 Oliver 88, 50 Oliver 88,50 Oliver 77, 72 Oliver 75 mower, 57 JD 720 , 45JD B, 48 Allis WC
  5. Remove Advertisements
  6. #1344
    Super Moderator BigDaveinKY's Avatar
    Cecilia, KY
    3,186
    5
    Quote Originally Posted by Aussie John View Post
    Hope the damage stays minor, and you all get some well needed moisture from the storm. I can recall several times the remnants of a hurricane brought us some needed relief from an extra dry summer. If I remember my grade school education properly, that type storm in the Atlantic ocean is called a hurricane, and the same type Pacific ocean storm is a cyclone. At least in the waters surrounding North America.
    No matter where you go.......There you are.
  7. #1345
    Senior Member
    2,937
    33
    John, I always hate to hear about hurricane damage no matter how slight. Hopefully just the right amount of rain will make it to your area and flooding if any will be minor.
  8. #1346
    Waterloo, IL.
    2,554
    55 this morning, going to a high of 65 today. Overcast.
    Steve
  9. #1347
    Moderator Jim in NC's Avatar
    Colfax, NC
    6,484
    105
    John, NC has had its share of hurricanes and been damaged by them. I believe flooding to be the worst damage that a hurricane can cause. Eastern NC was flooded extensively last fall by Matthew, and it will take many years for folks to recover. Hope you and all in Aussie Land escape the wrath of the storm.
    "Farming looks mighty easy when your plow is a pencil and you're a thousand miles from a cornfield." ~ Dwight D. Eisenhower
    "Heaven is under our feet as well as over our heads." Henry David Thoreau
  10. #1348
    Senior Member Wi11y's Avatar
    Jun 2016
    Sorrento, Maine
    600
    471
    But out in West Coast they dont have our wimpy huricanes. They have typhoons!
    Good luck man, hope all you get is some much needed rain and only fills your cisterns
    If it isnt broken, dont repair it.
  11. #1349
    Sep 2013
    Central Illinois
    825
    95
    45 now in central IL heading to a high of 58 with t storms
  12. #1350
    Cecilia, KY
    3,186
    5
    Starting at 47 degrees here in the middle of KY this morning. Headed to a high around 70. Definitely in the Spring weather pattern. Rain for a day and a half then dry for a day and a half. We're in the middle of the dry this morning.
