Results 1 to 5 of 5
    Moderator Jim in NC's Avatar
    Colfax, NC
    4,632
    15
    Does Anyone Know.....
    If a GE #284 sealed beam is a 6 or 12 volt light? I have searched the net and checked at a local parts house and haven't found much info on it at all. The last 12 volt ones I bought were 4411s. I want to use it cuz it works on 6 volts but is very dim.
  2. #2
    Moderator wizzard's Avatar
    symco,wi
    646
    look real close in good light with a magnifing glass it should say some place in realy small print.
    Bert.
  3. #3
    Moderator John M's Avatar
    Gray Court, SC
    1,819
    1
    Heck, I cant even find anything at all on a 284 bulb. Whats it go on, Jim?
    1939 F14, 1940 M (Sold), 2 1941 Ms - Consecutive Numbers, 1945 I-4, 1949 Cub, 1972 154 LoBoy
    bikerdave wrote: Defication occurrs! RIP My friend!!
  4. #4
    Colfax, NC
    4,632
    15
    It was the rear lamp on my Allis C. I've converted it to 12 volts and changed the fronts to 12 bulbs, I guess I could put 4411s there. The rear one was dim so it may be a 12 volter. I have had this thing under all sorts of light, but the only other markings I can find are "Made in USA" and a "D'. It's gotta be pretty old. The GE logo is in the front center.
  5. #5
    Gray Court, SC
    1,819
    1
    Quote Originally Posted by Jim in NC View Post
    Oh, that's a good thing!!!!! My bosses dad used to be the AC dealer in town, and he still has some of the old books. Ill look it up and see what I can come up with. Might have been a "cross over" bulb or something that I can find current.
