Results 1 to 4 of 4
Thread: Ethanol
    Moderator Jim in NC's Avatar
    Colfax, NC
    4,735
    17
    Ethanol
    If my thinking is correct, it seems ethanol subsidies were enacted to encourage its production to increase the supply of gasoline and make it more affordable.
    Under current conditions of rapidly falling fuel prices, it seems that if ethanol production subsidies continue, gasoline will be made more expensive.
    I also believed that ethonal subsidies were a form of political favoritism as well. I'd like to know from yall that are in corn country if there has been any talk of changing policies regarding ethanol production and blending with fuels since oil prices have dropped.
    Knowing that the production of ethanol requires more energy than it creates, it damages engines, and the craziness of burning food, now seems to be a good time to re-address the need to produce ethanol for fuel.
  2. #2
    Moderator John M's Avatar
    Gray Court, SC
    1,900
    I think those subsidies went away a couple of years ago, and according to some, the ethanol plants are still in full production. I for one have NEVER, ever had any problems running ethanol, either E10 or E85, and have never seen any of the "problems" people say they have. I have used the E10 in everything, and the E85 in all but one of my tractors, and have yet to have a single problem, even if it sits over the winter. I have had more problems storing nonethanol then E85. I suppose region has a lot to do with it though. (Rant ver!)
    1939 F14, 1940 M (Sold), 2 1941 Ms - Consecutive Numbers, 1945 I-4, 1949 Cub, 1972 154 LoBoy
    bikerdave wrote: Defication occurrs! RIP My friend!!
  3. #3
    Moderator Ernie N Ky's Avatar
    Clark County Kentucky
    702
    6
    We once had a Tahoe and it burnt E85 just fine, so we'll in fact that it got far less mpg. We switched back to gasoline because the cost was the same in the end and the only place with e85 was 20 miles away.
    Ernie N Ky
    Ford 8N
    Case VAC
    Farmall H
    Sears Custom 7
  4. #4
    Senior Member 4imnotright's Avatar
    Waterloo, IL.
    1,763
    0
    Several gas stations around here have quit the E85 completely
    Steve
    1956 Massey Harris 333
    1948 Allis Chalmers C w/ wide front end
