Results 1 to 4 of 4
Thread: Movin' Snow
    Cecilia, KY
    2,325
    Movin' Snow
    Mother Nature gave us the most snow we've ever seen at one time in the month of March. She dumped 20" in 18 hours.
    Was sure glad I bought that little Cub Cadet and front blade this past Spring. It can really move some snow, and the cab heats up good from the engine being right behind the seats. Though it did take three or four passes to find the bottom of the snow.
    Moderator Jim in NC's Avatar
    Colfax, NC
    4,990
    18
    Dave, I'm glad to see the CC is earning its keep well. I was talking with some friends less than hour ago and telling them how much precip you and KY have had over the last 2 days. I mentioned that if there is a quick warm up, flooding may not be far behind. I surely hope that is not the case.
    Stay warm and be safe.
  4. #3
    Moderator Ernie N Ky's Avatar
    Clark County Kentucky
    738
    6
    Sure looks better than my snow shovel!
    Ernie N Ky
    Ford 8N
    Case VAC
    Farmall H
    Sears Custom 7
  5. #4
    Senior Member
    Aloha, OR formerly Fargo-ND
    232
    0
    Warmer than my VAC Case had been in ND!
    Ya--All can keep that white stuff! Now you know why I am in OR; not ND! S--N--O--W-- was by far the biggest reason for the 1500+ mile re-location about 1/2 decade ago!
    Even more miserable when you are not used to it and do not have the resources at state and local levels for removal!
    just rjR
    Let me write about your collection; real or toys. I have a high published to submitted ratio.
