Results 1 to 2 of 2
Thread: 2600 Rear Rim
    Senior Member CTPhil's Avatar
    NW CT
    264
    0
    2600 Rear Rim
    I need to get a rear rim for my 2600 with 12.4 x 28 inch tires. The correct part seems to be C5NN1050E, but none of the rims I find with that number list 2600 as a model it works on, just older Fords. Any reason those wont work? What about a rim made of aluminum?
    Thanks!
    1949, 1951 Case VAC's, Ford 2600, 4100, 3550 Ind., IH 560, IH460 Utility
    Gravelys: L's, LI's, L8, C10, 524, 5460, 8102
    Cecilia, KY
    2,373
    4
    As long as the way it fits to your tractor is correct, it should work.
    An aluminum rim should work ok, they put them on a lot of cars these days.
