Results 1 to 2 of 2
    Senior Member Sugarmaker's Avatar
    Jun 2012
    1,602
    7
    Jubliee shifter repairs?
    Folks,
    It seems that the shift tower on the Jubilee has seen better days. I could not get it to shift into 1st or third. Finally popped the boot and found a elongated slot/hole and nothing engaging it. Pin looks to be completely worn away.
    By holding the shift lever straight, with both hands, I could get it to shift into those gears with no problem.
    Any suggestions of how you may have repaired one would be helpful.
    I have not taken the cover off yet. Looks like weld up the slot and install an new pin through the shifter ball?
    1950 Allis WD WFE
    1950 Allis WD NFE
    1951 Allis WD NFE
    1953 Ford Jubilee
    Cub Cadets 147R, (2) 127's, 125, 102 100, 86, and 73
    http://www.mapleandhoney.com
    Moderator John(IN)'s Avatar
    Mar 2012
    Franklin, IN
    172
    Are you sure it needs more than just a new pin?
    Learn something new every day!
