Results 1 to 2 of 2
    Member
    Aug 2013
    Whitehall, Indiana
    69
    C Starter Problems
    Ok,
    for the second time the starter shaft has broken on my c, both times it has broken inside the drive assembly. Is there a cause for this, or just a coincidence? it just seems odd for 2 starters to break in the same place. Any thoughts?
    Moderator
    Gray Court, SC
    2,288
    6
    Ive heard of this before, have you by chance changed it over to 12 volt? If you have, that's the problem. You need to change the battery to the small CCA you can find that will still turn the starter over. Saw on another forum where a guy uses a lawn mower battery in his C.
