| View previous topic :: View next topic |
| Author |
Message |
1031D Subscriber & Active Moderator
Joined: Mar 11 2008 User's Age: (30) Posts: 983 Location: Wisconsin member # 935
Posted: Sun Sep 06, 2009 1:46 am Post subject: Out plowing today |
Took the 1030 out for some plowing and wound up finishing with the VAC and BL plow as I broke a tie rod on the 1030.
 _________________ Jim
Lot's of Quality CASE Equipment used and serviced here! |
| Back to top |
R Wyler Member 1000 club
Joined: Feb 20 2007 User's Age: (30) Posts: 1806 Location: Oklahoma member # 31
Posted: Sun Sep 06, 2009 2:12 am Post subject: |
Great pics and the plows look like they are in nice and deep. Nice looking equipment also. I imagine that 1030 and Oliver semi mounted plow really get over some ground fast. _________________ Richard. Revelation 6:6 is nearing!!!!!![b]
Behold the Lion of the tribe of Judah the root of David has triumped. Revelation 5:5
[b] I plow with propane power... J.I. CASE chain drives RULE!!!!!!! |
| Back to top |
Cubguy Active Moderator
Joined: May 26 2009 User's Age: (22) Posts: 524 Location: Onsted, MI
Posted: Sun Sep 06, 2009 2:13 am Post subject: |
Cool pics and that tie rod does look broke.  _________________ Kyle
1940 farmall H, 1947 farmall cub, 1958 David Bradley Super Power, 1964 cub cadet 70, 1965 Bolens 1000, 1966 cub cadet 123, 1970 Mf 12
http://s222.photobucket.com/albums/dd207/truckguy_02/
| Back to top |
Posted: Sun Sep 06, 2009 2:16 am Post subject: |
I had that plow in about 8-10 inches or so. It is a model 5540 pipe plow. I had the 1030 in 3rd and 4th trying to get the bottoms to scour. Here are some videos! I like videos!
http://s496.photobucket.com/albums/rr328/1031d/My%20Videos/ _________________ Jim
| Back to top |
Posted: Sun Sep 06, 2009 2:29 am Post subject: |
Yes those are great plows. Wonderful videos also  _________________ Richard. Revelation 6:6 is nearing!!!!!![b]
| Back to top |
Posted: Sun Sep 06, 2009 2:33 am Post subject: |
It looks like you were having fun with your brute too! Aint it amazing how strong those power cell engines are? My pump is turned up a little so it gives some smoke for effect Gotta have smoke and noise, or else they might think you broke it or you are taking a nap! _________________ Jim
| Back to top |
CKRICHARD Active Moderator
Joined: Feb 21 2007 User's Age: (45) Posts: 374 Location: Kentucky member # 32
Posted: Mon Sep 07, 2009 1:33 am Post subject: |
I would love to plow with my 1030 that thing is a beast . Ive never seen a broken yoke before , should not be that hard to find one 400 730 830 930 and 1030 all the same. I had one but scraped it a few years ago. _________________ Hooked on Case |
| Back to top |
Peterbilt Member
Joined: Aug 31 2008 User's Age: (25) Posts: 242 Location: Sandusky, Ohio member # 1341
Posted: Mon Sep 07, 2009 9:50 pm Post subject: |
Those VAC's make nice little work horse. I use a 3 piont 2 bottom on mine and dose a good job. Would be better if I could find front wheel weights for it thou. _________________ 1940 Ford 9N
1952 Ford 8N
1946 Case VAC
1949 Case VAC
1949 Case DC-4
1939 John Deere B
Sold
1939 Ford 9N
1939 Farmall H
1944 Case VAC |
| Back to top |
