View Caseman's Pictures
^Click to View Caseman's Pics^
Antique Tractors Forum
Pictures & Discussion Of Antique Tractors & Machinery
Log inLog in  FAQFAQ  CalendarCalendar  RegisterRegister
Support this Site  Guestbook  Exchange Links
Help needed
Post new topic   Reply to topic    Antique Tractors Forum Forum Index -> Allis-Chalmers
View previous topic :: View next topic
Author Message
MoreNuff
Member
Member
User's Age: N/A
PostPosted: Sat Sep 19, 2009 8:23 pm    Post subject: Help needed Reply with quote
Hi all - In the late 1970's Leyland Tractors here in the UK imported two Allis-Chalmers tractors, one 130hp and the other 150hp. I don't know the AC model numbers.
They were imported into the UK as part of an evaluation project to provide a quick and easy answer to incorporate higher HP models into the Leyland range of tractors. They were painted Leyland Golden Harvest and had the model numbers 1302 and 1502.
The project was cancelled when Leyland sold the tractor division to Marshall tractors in 1981. The tractors were shipped to the Marshall factory in Gainsborough, England and subsequently returned to the Leyland tractor HQ at Harrisburg, Pennsylvania USA in about 1984/5. They were then exported to Canada and sold through a company called Albert Swanston Farm Equipment in Ontario.
I am trying to trace the whereabouts of these tractors, does anyone know anything about them or know where they may be? Or could anyone suggest who I should contact for further information.
Cheers - MoreNuff
_________________
If it ain't bust don't fix it!
Back to top
View user's profile Send private message
Jhaydeno
Member
Member
User's Age: (39)
PostPosted: Sun Sep 20, 2009 1:32 pm    Post subject: Reply with quote
I'm only 15 minutes from Harrisburg, PA (USA). If you need me to look up any local info at the library pease drop me a note.
Jeff O'
_________________
I enjoy fixing anything with wheels!
Back to top
MoreNuff
Member
Member
User's Age: N/A
PostPosted: Sun Sep 20, 2009 5:54 pm    Post subject: Harrisburg Reply with quote
Hi Jeff - Thank you for your very kind offer of help. The facility was at; 67 Allen Town Blvd. but was closed down a number of years ago. I don't know if any records exist and if they do what information they may contain. Whether it would be possible to track down any former workers from there I don't know. I am in touch with the former CEO who gave me the information about the two tractors going to Canada. Maybe the library has some historic records. What I really want above all else are good pictures, but you never know, one day .....
I have a very, very poor quality 3rd generation b/w photocopy picture of them which is proof that they actually did exist. If I were to post them on here I wonder it anyone could identify the original Allis-Chalmers model numbers? I'll look them out and post tomorrow. Again many thanks for your offer of help.
MoreNuff
_________________
Back to top
John(IN)
Active Moderator
Active Moderator
User's Age: (67)
PostPosted: Sun Sep 20, 2009 7:07 pm    Post subject: Reply with quote
At 130 HP and 150 HP from the mid 1970's my guess would be the A-C model 7030 and 7050 tractors.
_________________
Learn something every day!
Back to top
View user's profile Send private message Send e-mail
JJ. in B.C.
Active Special Moderator
User's Age: (68)
PostPosted: Sun Sep 20, 2009 8:20 pm    Post subject: Reply with quote
You could also try contacting
Swanston Farm Equipment Ltd
RR#3, Rockwood. Ontario. N0B 2K0
_________________
JJ.
48' Farmall Cub
51' JD AR
58' JD 70 Diesel
65' MF 135 UK Diesel
Back to top
MoreNuff
Member
Member
User's Age: N/A
PostPosted: Mon Sep 21, 2009 1:57 pm    Post subject: Allis-Chalmers Reply with quote
Hi JJ - Thanks for that, I've sent them an email and await a reply.
John I was looking at some images of Allis-Chalmers tractors and thought they may be 7000 series.
Here are two pictures, sorry about the poor quality.
Regards MoreNuff
_________________
Back to top
BigDaveinKY
Subscriber & Active Special Moderator
User's Age: (50)
PostPosted: Mon Sep 21, 2009 2:24 pm    Post subject: Reply with quote
Definately look like the 7000 series A-C. Good luck with your search.
Please let us know when you find them.
_________________
ALWAYS REMEMBER:
No matter where you go...There you are!
Back to top
wizzard
Subscriber & Active Moderator
User's Age: (38)
PostPosted: Mon Sep 21, 2009 9:14 pm    Post subject: Reply with quote
i remember hearing rumers that A-C was workin with leyland years ago i gess it was true! thanks for the pics MoreNuff
_________________
Bert
1935 Case L threshermans special
1943 Farmall H
1968 Nuffield 4/65
the twins 2-1969 Nuffield 4/65's
Back to top
MoreNuff
Member
Member
User's Age: N/A
PostPosted: Thu Nov 05, 2009 9:41 pm    Post subject: Serial Numbers Reply with quote
Hi All - Can anyone tell from the following serial numbers what the Horse Power of each tractor is:- 7000-3019 & 7000-4908. Any information would be invaluable. I believe I have now tracked down these two tractors to Ontario, Canada. - MoreNuff
_________________
Back to top
BigDaveinKY
User's Age: (50)
PostPosted: Fri Nov 06, 2009 2:32 pm    Post subject: Reply with quote
Morenuff the h.p. rating of the 7000 is 106 from the tests.
Those serial numbers make both machines 1976 models.
Hope this helps. Very Happy
_________________
ALWAYS REMEMBER:
Back to top
John(IN)
Active Moderator
Active Moderator
User's Age: (67)
PostPosted: Fri Nov 06, 2009 10:18 pm    Post subject: Re: Serial Numbers Reply with quote
Do you know where the serial number was located on those tractors? Was it facing the rear or facing the wheel?
_________________
Back to top
MoreNuff
Member
Member
User's Age: N/A
PostPosted: Wed Nov 11, 2009 7:35 pm    Post subject: Leyland Allis Reply with quote
Hi all - Thanks for the info. I've never seen these tractors so I don't know where the serial numbers are located.
When I wrote; "Can anyone tell from the following serial numbers what the Horse Power of each tractor is:- 7000-3019 & 7000-4908." I probably misled you, I wrote 7000 rather than 7010 or 7020, I did this because I hoped that someone could let me know the HP's from the serial numbers. When these tractors were in the UK they were supposed to be 130 and 150 HP, but when they turned up in Canada they became 110 and 120 HP. I have been assured that the tractors are the same ones.
Can anyone tell me the production years for the 7010, 7020, 7030 and 7050? I believe they were built in different decades and not all together. I also believe each range had there own serial numbering sequence is this correct? The two tractors are reputed to have been built in 1981, would this be correct if they were 7010 and 7020 and would it be correct to say that if they were 7030 and 7050's they were built in the middle 1970's? - MoreNuff
_________________
Back to top
John(IN)
Active Moderator
Active Moderator
User's Age: (67)
PostPosted: Thu Nov 12, 2009 1:37 am    Post subject: Reply with quote
Hi,
7030 and 7050 were both built in 1973 ad 1974 with the final serial number for 7030 being 4398 and the final 7050 being 3300.
Models produced in 1981 were 7010 serial numbers 2806 thru 3433, 7020 serial numbers 4710 thru 5209, 7045 serial numbers 4255 thru 4888, 7060 serial numbers 8442 thru 9142 and 7080 serial numbers 3954 thru 4225. Production of the 7000 series tractors ended in 1981 with the 8000 series begining near the end of 1981. And yes the original model number should have preceded the serial number.
The 7010 tested at 106 PTO HP and the 7020 at 123 PTO HP
This information is from the book by Norm Swinford "Allis-Chalmers Farm Equipment 1914-1985"
_________________
Back to top
MoreNuff
Member
Member
User's Age: N/A
PostPosted: Thu Nov 12, 2009 8:32 am    Post subject: Allis-Chalmers 7010 and 7020 Reply with quote
Hi John - Thank you so much for the information, it has helped me a lot and cleared up a few doubts. - MoreNuff
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    Antique Tractors Forum Forum Index -> Allis-Chalmers All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Google
Powered by phpBB © 2001, 2005 phpBB Group
