View Caseman's Pictures
^Click to View Caseman's Pics^
Antique Tractors Forum
Pictures & Discussion Of Antique Tractors & Machinery
Log inLog in  FAQFAQ  CalendarCalendar  RegisterRegister
Support this Site  Guestbook  Exchange Links
Modified F-12 question
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    Antique Tractors Forum Forum Index -> Farmall-International
View previous topic :: View next topic
Author Message
DerickS
Active Moderator
Active Moderator
User's Age: (37)
PostPosted: Tue Jul 13, 2010 9:16 pm    Post subject: Modified F-12 question Reply with quote
My friend has this F-12 that he put together from spare parts and the engine and clutch is out of an industrial type machine....I thought combine but he said no it was a stationary. I dont know enough to tell for sure Confused The clutch will engage but not disengage, I opened the inspection plate and saw a collar with a grease fitting and line that slides over a bearing of some type. The collar or bearing is worn and wont disengage the clutch. The question is can I service this bearing without breaking the tractor in two?
_________________
1951 Allis Chalmers CA
1948 MH model 20
1947 Allis Chalmers WC
1947 Modell M Farmall
1946 Model A Farmall
1945 Minneapolis Moline ZTS
1942 Oliver RC 60 originally on steel conv to rubber
1968 Simplicity Broadmoor lawn tractor
Back to top
View user's profile Send private message Send e-mail Visit poster's website
John M
Member 500 club
Member 500 club
User's Age: (41)
PostPosted: Tue Jul 13, 2010 10:10 pm    Post subject: Reply with quote
Got a pic of the clutch area. If it were factory 12, then yes, but I need to see how the clutch is adapted to the tracotr and engine.
_________________
2 1941 Farmall Ms (Consecutive Numbers), 1940 M, 1939 F14, 1949 Cub, 1945 I-4, 1971 154 LoBoy
Back to top
DerickS
Active Moderator
Active Moderator
User's Age: (37)
PostPosted: Tue Jul 13, 2010 10:53 pm    Post subject: Reply with quote
I screwed up and didnt get the pic....I will have it by this weekend though. The shaft comes out of the trans and three bolts to the shaft coming out of the trans. Its all covered by a metal half circle bolt on cover, if that helps
_________________
1948 MH model 20
Back to top
DerickS
Active Moderator
Active Moderator
User's Age: (37)
PostPosted: Mon Jul 19, 2010 11:18 pm    Post subject: Reply with quote
Here are some pic's of my predicament Laughing I'm about ready to break the tractor in half but i'm not sure how to get the straight clutch shaft out of the bell housing?
What do you guys think?
_________________
1948 MH model 20
Back to top
DerickS
Active Moderator
Active Moderator
User's Age: (37)
PostPosted: Wed Jul 21, 2010 1:39 am    Post subject: Reply with quote
Help.....anyone?
_________________
1948 MH model 20
Back to top
carpman15
Moderator
Moderator
User's Age: (22)
PostPosted: Wed Jul 21, 2010 2:15 am    Post subject: Reply with quote
i moved it down here i dont know if it will help or not but we will try it
_________________
1941 Farmall M (she lives again after 30 years)
old stationary buzz saw know nothing about it
Mc Cormick-Deering No 3?? single bottom
Back to top
jd2840
Active Moderator
Active Moderator
User's Age: (13)
PostPosted: Wed Jul 21, 2010 2:54 am    Post subject: Reply with quote
i would help but i dont have a manual on this tractor. Confused i supose it would be different than the letter seires and it has a different clutch Confused
_________________
-Ray-
My collection counting both grandpa's Very Happy
1937 Farmall F-20
1939 Allis Chalmers B
1941 Farmall H
1944 Farmall M
1949 Farmall H
1954 Farmall Super M-TA
1955 4400 Chevy Truck
M-H no. 8
IHC no.9
2 John Deere 120bs
IH Model MF grain drill
Old Wagon
IH 1 Row Planter (converted for tractor)
25ft Long 8ft Wide Trailer (Brand Unknown)
Back to top
View user's profile Send private message Visit poster's website
Grizz
Member
Member
User's Age: (48)
PostPosted: Wed Jul 21, 2010 3:58 am    Post subject: Reply with quote
I'm not sure if the problem is
the clutch won't disengage ever
or
it will engage ,then won't disengage,
Anyway that clutch is an over center industrial type , it has an adjustment pin , visible in on of the pictures and the pressure ring is threaded to provide for adjustment , it doesn't take much out of adjustment for the clutch to either slip or not disengage , if the collar is still connected to the throw out ring it should be Ok
BTW that is probably a push to engage , pull to disengage type , opposite of a "normal " clutch
_________________
1958 JD 820
A fleet of JD 96 combines
1988 379exhd Pete 3406 CAT
Pettibone super 20
A bunch of other junk
Back to top
John M
Member 500 club
Member 500 club
User's Age: (41)
PostPosted: Wed Jul 21, 2010 10:27 am    Post subject: Reply with quote
Wish I could help ya out, but Ive never been inside the clutch on a power unit/stationary unit before. Seems though that there should be a couple of bolts on that shaft or on the TO bearing carrier or somewhere in there to take out and allow the shaft to slide out.
_________________
Back to top
1031D
Subscriber & Active Moderator
User's Age: (30)
PostPosted: Wed Jul 21, 2010 11:13 am    Post subject: Reply with quote
That clutch looks identical to the one in my MM ZAU. I did the clutch in my F-12 easy enough but it didn't look like he left enough room to pull the bell housing cover off and clear the input of the trans, that's why they have such a big coupler in there from the factory. When you do get it apart take the shaft out of the bell housing and cut it off shorter and put the factory F-12 center piece in there so next time it's a breeze.
_________________
Jim
Lot's of Quality CASE Equipment used and serviced here!
Back to top
View user's profile Send private message Visit poster's website Yahoo Messenger
DerickS
Active Moderator
Active Moderator
User's Age: (37)
PostPosted: Wed Jul 21, 2010 12:01 pm    Post subject: Reply with quote
How do I get the shaft out of the side of the bellhousing? there are no external bolts, is there something internal i need to take loose? the bolt on top of the collar you can see in the pic was tight but I cant see the bottom half. the collar slips right onto the shaft when the lever is pushed forward it will slide up and onto the shaft and engage the clutch it just wont disengage.
_________________
1948 MH model 20
Back to top
Grizz
Member
Member
User's Age: (48)
PostPosted: Wed Jul 21, 2010 1:45 pm    Post subject: Reply with quote
I have seen quite a few industrial drive set ups like that where the throw out shaft is a solid piece, and has the throw out fingers welded to the shaft , and therefor not remove able . I will try to find a exploded pic from a crane manual
_________________
1958 JD 820
Pettibone super 20
Back to top
DerickS
Active Moderator
Active Moderator
User's Age: (37)
PostPosted: Wed Jul 21, 2010 2:29 pm    Post subject: Reply with quote
Thanks, for the help anything you can do to help is greatly apprecitated
_________________
1948 MH model 20
Back to top
DerickS
Active Moderator
Active Moderator
User's Age: (37)
PostPosted: Wed Jul 21, 2010 2:31 pm    Post subject: Reply with quote
Looking at the pictures i cant even get the bellhousing out because of the frame rails!
_________________
1948 MH model 20
Back to top
bikerdave
Member 1000 club
Member 1000 club
User's Age: (66)
PostPosted: Wed Jul 21, 2010 3:05 pm    Post subject: Reply with quote
It got in there, it will come out! May not be easy.
_________________
2005 Craftsman LT-1000, 1977 1450 Cub Cadet, 1969 110 John Deere + 2006 Honda VTX 1300S and looking
Back to top
Display posts from previous:
Post new topic   Reply to topic    Antique Tractors Forum Forum Index -> Farmall-International All times are GMT
Page 1 of 3
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Google
Powered by phpBB © 2001, 2005 phpBB Group
