| Author |
Message |
HarleyHog Member
Joined: May 26 2010 User's Age: N/A Posts: 10 Location: Blue Ridge Mtns Virginia
Posted: Wed Jul 21, 2010 4:09 pm Post subject: |
| Nicely done! Cant wait til we get the A back together which coincidentally had to be torn apart b/c of NO oil pressure. Again, your B looks great. |
| Back to top |
DC Snider Member 250 club
Joined: Sep 30 2008 User's Age: (42) Posts: 291 Location: Princeton, WV member # 1433
Posted: Wed Jul 21, 2010 5:22 pm Post subject: |
Good job Corey...I don't blame ya' for wantin' to keep it either. Hope you get the oil pressure figured out. Wish I could offer some direction for ya'
Dusti _________________ "Trouble is only opportunity in work clothes"
1951 Farmall M
1967 John Deere 112H
1973 John Deere 140 H3
1956 Ford 640 |
| Back to top |
04mustang Member 250 club
Joined: Dec 05 2007 User's Age: (21) Posts: 493 Location: lumberton, NC member # 645
Posted: Thu Jul 22, 2010 2:31 pm Post subject: |
Im hoping that I dont have to tear this one apart again just to fix the oil pressure.
does anyone have a drawing of the way this tractor keeps itself lubed? I know its got plenty of oil, we follow the manual, 7 quarts. maybe i didn't tighten the oil guage enough this is bothering me, im now second guessing everything I did during the restoration.
Thanks again to everyone for the comments and the help!
On a side note: does anyone have a spare step for this tractor that they would want to part with? _________________ To know God in a personal way is everything!
JD 320S with 4100 cultivator (restored)
JD 420S with KBL disc (restored)
JD 420W (restored)
JD 420T (restored)
JD B late styled (under restoration)
JD 2150 (original)
IH Farmall Cub (1949) with cultivators (restored)
IH Farmall Cub (1952) with planters and fertilizer unit (restored) |
| Back to top |
Posted: Thu Jul 22, 2010 7:19 pm Post subject: |
Corey,
I thought I posed this link eariler...but apparently not. I've got alot of stuff saved on my computer and I thought about this last night. Just took me a while to come up with a link. Good readin' here and it may help you. I learned alot and I don't even own one.
http://www.jdhpubs.com/pdf/Appendix14.pdf
1951 Farmall M
1956 Ford 640 |
| Back to top |
Posted: Fri Jul 23, 2010 12:21 am Post subject: |
thanks dusti, one question... on the B we replaced the oil guage line with a new one from deere, it just had brass fittings that screwed into the top of the crank case and the other end had a fitting that angled over and went into the guage.
is this all there is? This would suggest that the entire crank case is under pressure. am I missing something? _________________ To know God in a personal way is everything!
JD 420W (restored)
JD 420T (restored)
JD 2150 (original)
| Back to top |
HarleyHog Member
Posted: Fri Jul 23, 2010 12:27 am Post subject: |
| 04mustang wrote: | thanks dusti, one question... on the B we replaced the oil guage line with a new one from deere, it just had brass fittings that screwed into the top of the crank case and the other end had a fitting that angled over and went into the guage.
is this all there is? This would suggest that the entire crank case is under pressure. am I missing something? |
The other end of that fitting goes to the oil pump. |
| Back to top |
Shockwave Member
Posted: Sun Aug 01, 2010 7:46 pm Post subject: |
good job!!  _________________ International McCormick 523s
| Back to top |
Posted: Mon Aug 02, 2010 12:24 am Post subject: |
Thank you very much, im still trying to figure out the oil pressure issue. The best we can figure is that it's got about 4-5 lbs of pressure on it, but the guage isnt reading much. _________________ To know God in a personal way is everything!
JD 420W (restored)
JD 420T (restored)
JD 2150 (original)
| Back to top |
Dean Member
Joined: Mar 18 2007 User's Age: (48) Posts: 243 Location: Cynthiana, Kentucky member # 137
Posted: Mon Aug 02, 2010 11:47 pm Post subject: |
Hey that looks great. Can't wait to get my 1953 JD40S finished. It's been slow go. Hope it turns out as good looking as yours. _________________ God Bless
Dean
This World Is Not My Home I'm Just A Passin' Through. |
| Back to top |
txrick Member
Joined: Aug 03 2010 User's Age: N/A Posts: 24 Location: Republic of Texas
Posted: Sun Aug 29, 2010 5:05 pm Post subject: |
| According to DC Snider's link,the oil pressure is adjustable, turn the screw clockwise a half turn & check what your gauge reads, keep going until it reads 10 - 15 lbs at idle. Check your gauge reading by installing a low pressure stewart warner gauge ( 10 - 30lbs ) to verify what your present gauge is reading. |
| Back to top |
