| Author |
Message |
Rusty6 Member
Joined: Oct 26 2008 User's Age: N/A Posts: 163 Location: S.E. Sask. Canada member # 1480
Posted: Thu Jul 22, 2010 3:56 am Post subject: John Deere 7721 |
Although its hardly an antique at 23 years old this 87 model 7721 JD pull type combine is new to me. Very well kept machine for its age and I'm hoping it will do a real good job harvesting my flax.
The 7721 Titan II was the last of that series before they came out with the Maximizers including the 9501 pull type.
 _________________ Cockshutt 50,40, and various IH trucks, etc. |
| Back to top |
kiwi071 Active Moderator
Joined: Dec 25 2007 User's Age: (71) Posts: 10073 Location: Christchurch, New Zealand member # 679
Posted: Thu Jul 22, 2010 7:21 am Post subject: |
Thanks for posting Rusty,two tidy looking machines.  _________________ kiwicolin |
| Back to top |
prwttsh Active Moderator
Joined: Feb 22 2007 User's Age: N/A Posts: 3380 Location: N. Illinois member # 45
Posted: Fri Jul 23, 2010 2:42 am Post subject: |
Thanks Rusty. We don't have any pull type around here anymore. (got a good looking tractor on it too ) _________________ Rain makes grain
Bruce |
| Back to top |
Mr. Green Member 250 club
Joined: Sep 03 2009 User's Age: (16) Posts: 469 Location: South Dakota
Posted: Fri Jul 23, 2010 4:53 am Post subject: |
Both machines look really nice. What model Magnum is that? _________________ John
Green Jobs involve a John Deere or Oliver.
"If the women don't find you handsome, they should at least find you handy"- Red Green
My tractors:
David Bradley Super Power
Ford 2N |
| Back to top |
Rusty6 Member
Posted: Fri Jul 23, 2010 6:12 am Post subject: |
| Mr. Green wrote: | Both machines look really nice. What model Magnum is that? |
Thats my 7130. Its a 1992 model and I think the 18 speed power shift and front wheel assist should make it a good match for the combine. _________________ Cockshutt 50,40, and various IH trucks, etc. |
| Back to top |
bikerdave Member 1000 club
Joined: Mar 11 2008 User's Age: (66) Posts: 1306 Location: Portsmouth, Va.-member#933
Posted: Fri Jul 23, 2010 1:29 pm Post subject: |
Sure you got enough tractor? Awful big combine. _________________ 2005 Craftsman LT-1000, 1977 1450 Cub Cadet, 1969 110 John Deere + 2006 Honda VTX 1300S and looking |
| Back to top |
Rusty6 Member
Posted: Fri Jul 23, 2010 3:44 pm Post subject: |
| bikerdave wrote: | | Sure you got enough tractor? Awful big combine. |
I have no doubt the 7130 will do fine. A neighbour pulls the same combine with a 2 WD John Deere . Recommended size is minimum 125 hp. Mine is conservatively rated at 170 hp so no worries. _________________ Cockshutt 50,40, and various IH trucks, etc. |
| Back to top |
NCcountryboy Member
Joined: Sep 30 2009 User's Age: (29) Posts: 233 Location: Western NC
Posted: Fri Jul 23, 2010 3:52 pm Post subject: |
I have saw a JD 4630 pull one in a picture once. It has 150HP, so the CIH should do well with it. |
| Back to top |
Olsem Member
Joined: Oct 12 2009 User's Age: (27) Posts: 47 Location: Elkhart, Iowa
Posted: Sun Jul 25, 2010 7:59 pm Post subject: |
| I didnt even know that model was around! There enough room to unload on the go? Can you switch it over to a corn head? Whats it got for a monitor? |
| Back to top |
Rusty6 Member
Posted: Mon Jul 26, 2010 3:27 am Post subject: |
| Olsem wrote: | | I didnt even know that model was around! There enough room to unload on the go? Can you switch it over to a corn head? Whats it got for a monitor? |
This 7721 is just a pull type of the 7720 self propelled and they were a very popular combine here. That is a pickup header only designed for picking up swaths so no straight cutting. It has a full set of grain and shaft monitors in the tractor cab as well as a cylinder tach. Its got a good long unloading auger and if I take the duals off the tractor is should be no problem unloading on the go. Corn headers are not really needed up this far north as no corn is grown except in gardens. _________________ Cockshutt 50,40, and various IH trucks, etc. |
| Back to top |
Olsem Member
Posted: Mon Jul 26, 2010 11:28 pm Post subject: |
| You guys have to cut the crop when its still green to prevent shatter loss...right? |
| Back to top |
Rusty6 Member
Posted: Tue Jul 27, 2010 2:35 am Post subject: |
| Olsem wrote: | | You guys have to cut the crop when its still green to prevent shatter loss...right? |
Only canola, and some have even tried straight cutting that but I think it has not caught on too well.
Cereal grains we mostly straight cut now. Some will dessicate with roundup before harvest to even out the ripening. I have straight cut oats and it worked fairly well although I know some did shell out.
Flax I usually like to swath and let lay til it ripens and dries the tough wiry straw out some. Although last year I had it straight cut in late fall by custom. It was a strange year and the straw was still tough getting through even at that late date. _________________ Cockshutt 50,40, and various IH trucks, etc. |
| Back to top |
