| Author |
Message |
rustytenn Member
Joined: Nov 06 2007 User's Age: N/A Posts: 19 Location: tennessee member # 584
Posted: Fri Jul 30, 2010 12:42 am Post subject: gas coming from exhaust pipe?? |
I"ve got a farmall 140.The tractor set for several years. I got tractor runnin but recently noticed gas comin frombottom of muffler[top of exhaust manifold.] And is floodin itself out and will not run.I took carb[marvel-scheibler] off and cleaned up good and put a rebuild kit in it.It fired right up and went to use and ran good for a few minutes but done same thing.float sticking? or something else?? _________________ 200? kubota 7510 , 197? john deere 4430 ,198? john deere 650 ,1961 farmall 140 19?? farmall 140, 19?? farmall hc 140 |
| Back to top |
daddys big bad m Member
Joined: Jul 10 2010 User's Age: (48) Posts: 34 Location: west terre haute indiana
Posted: Fri Jul 30, 2010 12:46 am Post subject: Re: gas coming from exhaust pipe?? |
| rustytenn wrote: | | I"ve got a farmall 140.The tractor set for several years. I got tractor runnin but recently noticed gas comin frombottom of muffler[top of exhaust manifold.] And is floodin itself out and will not run.I took carb[marvel-scheibler] off and cleaned up good and put a rebuild kit in it.It fired right up and went to use and ran good for a few minutes but done same thing.float sticking? or something else?? | had same thing happen on ford 8n. turned out my float had a hole in it and it was actually sinking. Did you replace needle and seat together? Older sets are a machined needle and seat and should be replaced together or you might not get a good seal. I'm leaning towards bad float though _________________ crops are green, tractors are red! |
| Back to top |
rustytenn Member
Posted: Fri Jul 30, 2010 12:50 am Post subject: |
yes i put new needle and seat but did not put a new float _________________ 200? kubota 7510 , 197? john deere 4430 ,198? john deere 650 ,1961 farmall 140 19?? farmall 140, 19?? farmall hc 140 |
| Back to top |
Bigdog Subscriber
Joined: Jun 08 2010 User's Age: (63) Posts: 64 Location: Stoutsville, OH
Posted: Fri Jul 30, 2010 1:30 am Post subject: |
It could also be some dirt under the needle valve keeping it from closing completely. Did you use some sealant under the seat. Sometimes they will leak from behind the seat. _________________ Electrical problems require a smaller hammer! |
| Back to top |
rustytenn Member
Posted: Fri Jul 30, 2010 1:37 am Post subject: |
no i didnt. did not really think about that. i will probly pull carb back off in next day or two and check it out _________________ 200? kubota 7510 , 197? john deere 4430 ,198? john deere 650 ,1961 farmall 140 19?? farmall 140, 19?? farmall hc 140 |
| Back to top |
John M Member 500 club
Joined: Mar 29 2008 User's Age: (41) Posts: 945 Location: Gray Court SC member # 978
Posted: Sat Jul 31, 2010 4:36 pm Post subject: |
| Bigdog wrote: | | It could also be some dirt under the needle valve keeping it from closing completely. Did you use some sealant under the seat. Sometimes they will leak from behind the seat. |
Ive never put any type of sealant on a seat before, the kits I get have a small round gasket for that. Just curious what type of sealant your using there. _________________ 2 1941 Farmall Ms (Consecutive Numbers), 1940 M, 1939 F14, 1949 Cub, 1945 I-4, 1971 154 LoBoy
| Back to top |
Bigdog Subscriber
Posted: Sat Jul 31, 2010 7:43 pm Post subject: |
Sometimes the washers (gaskets) will not seal due to pitting of metal of the body. A very thin coat of sealant such as black permatex on the washer. Apply with a toothpick - it doesn't take much - and it can prevent a problem. _________________ Electrical problems require a smaller hammer! |
| Back to top |
Posted: Sat Jul 31, 2010 10:43 pm Post subject: |
| Bigdog wrote: | | Sometimes the washers (gaskets) will not seal due to pitting of metal of the body. A very thin coat of sealant such as black permatex on the washer. Apply with a toothpick - it doesn't take much - and it can prevent a problem. |
I have to admit that Ive never had that problem. I guess Ive been lucky so far. _________________ 2 1941 Farmall Ms (Consecutive Numbers), 1940 M, 1939 F14, 1949 Cub, 1945 I-4, 1971 154 LoBoy
| Back to top |
