View Caseman's Pictures
^Click to View Caseman's Pics^
Antique Tractors Forum
Pictures & Discussion Of Antique Tractors & Machinery
Log inLog in  FAQFAQ  CalendarCalendar  RegisterRegister
Support this Site  Guestbook  Exchange Links
Farmall Cub Starting Issues
Post new topic   Reply to topic    Antique Tractors Forum Forum Index -> Farmall-International
View previous topic :: View next topic
Author Message
jeffgiowa
Member
Member
User's Age: (42)
PostPosted: Sat Jul 31, 2010 4:18 pm    Post subject: Farmall Cub Starting Issues Reply with quote
Hello gang-
My cub will not start with starter but I park it on a hill and it starts immediately. Has new plugs, recent points, good compression. Any ideas?
Back to top
View user's profile Send private message Send e-mail
John M
Member 500 club
Member 500 club
User's Age: (41)
PostPosted: Sat Jul 31, 2010 4:32 pm    Post subject: Re: Farmall Cub Starting Issues Reply with quote
jeffgiowa wrote:
Hello gang-
Mag or distributor?
_________________
2 1941 Farmall Ms (Consecutive Numbers), 1940 M, 1939 F14, 1949 Cub, 1945 I-4, 1971 154 LoBoy
Back to top
Bigdog
Subscriber
Subscriber
User's Age: (63)
PostPosted: Sat Jul 31, 2010 7:35 pm    Post subject: Reply with quote
If it is battery ignition you may have a weak battery that is pulling down while turning the starter. Poor battery connections are another source of loss. All connections should be clean, shiny and tight.
If you can, put a voltmeter across the battery terminals and monitor the voltage of the battery just setting there and then while cranking the engine over. It will give you some idea of whether you are losing energy in the circuit.
_________________
Electrical problems require a smaller hammer!
Back to top
View user's profile Send private message Send e-mail Visit poster's website
jeffgiowa
Member
Member
User's Age: (42)
PostPosted: Sat Jul 31, 2010 10:26 pm    Post subject: Reply with quote
Cub has new battery and will start perfectly with starter once warmed up. Only way to start it cold is on the hill. Has dist. ignition
Back to top
John M
Member 500 club
Member 500 club
User's Age: (41)
PostPosted: Sat Jul 31, 2010 10:47 pm    Post subject: Reply with quote
Hmmmm. Does the starter spin over pretty fast cold, or does it just kinda roll over slowly. Theres no reason why it shouldnt start off of the starter cold unless the battery is weak. Im thinking that there may be a problem with either the starter or the cables. Also, which gear are you starting it in when you roll it down here.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    Antique Tractors Forum Forum Index -> Farmall-International All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Google
Powered by phpBB © 2001, 2005 phpBB Group
